[vcf-midatlantic] Repairs to a Heath WH19 Terminal
Matt Patoray
mspproductions at gmail.com
Thu Mar 16 00:07:59 EDT 2017
Jason,
That is great news! That is also too much AC on a DC rail, I would suspect those caps and get replacements, 1500 uF would be hard to find but a 2200 would be ok in this case, remember those older electrolytics may have a tolerance of -20% +85% and modern caps are all +- 20% or better.
Sent from my iPhone
> On Mar 15, 2017, at 10:17 PM, Jason Perkins via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> Replacing the shorted cap and blown current limiting resistors results in
> signs of life!
> https://goo.gl/photos/nk5kvxuCT2VGztgf6
> Good: The terminal works! https://goo.gl/photos/TPoPQ1c8QajthkZM7 (yes, I
> tested with a loopback adapter, then with a usb to RS232 adapter before
> hooking it up to the Lisa :) ) The terminal draws 51 watts running. Nothing
> inside seems to be getting unusually hot.
> Problems: The display has a major wave.
> https://goo.gl/photos/wXKydMr5syKU1SWd7 Guessing there are more bad caps in
> the video section. The 65V input, and 53V rail in the monitor have .5v of
> ac ripple. Perhaps the big 1500uf electrolytic is going bad...
> The keyboard didn't work very well at first, but after typing on it for a
> bit it now works perfectly.
> -J
> On Mon, Mar 13, 2017 at 12:10 PM, Jason Perkins <perkins.jason at gmail.com>
> wrote:
>> Man what a small world... My other big not-work time investment is
>> TDIClub, looks like the OP of that article is into TDIs a bit as well!
>>> On Mon, Mar 13, 2017 at 11:56 AM, Neil Cherry <ncherry at linuxha.com> wrote:
>>>> On 03/12/2017 11:25 PM, Jason Perkins via vcf-midatlantic wrote:
>>>> You were right, the big .22 600v cap C232 was shorted. I've placed an
>>>> order
>>>> from DigiKey, hopefully the impending snow doesn't delay things too
>>>> badly.
>>>> -J
>>>> On Sun, Mar 12, 2017 at 6:55 PM, David Gesswein via vcf-midatlantic <
>>>> On Sun, Mar 12, 2017 at 05:43:22PM -0400, Jason Perkins via
>>>>>> There aren't many things on that ground return from the flyback, I'll
>>>>> take
>>>>>> them out one at a time till I find the shorted part.
>>>>>> The caps to ground look like the most obvious path to create a short.
>>> Queue eerie Twilight Zone Music:
>>> http://hackaday.com/2017/03/13/raspberry-pi-hitches-ride-ins
>>> ide-vintage-terminal/
>>> ... but he quickly determined that a bad cap was shorting out the -12VDC
>>> rail ...
>>> hehe
>>> Linux Home Automation Neil Cherry ncherry at linuxha.com
>>> http://www.linuxha.com/ Main site
>>> http://linuxha.blogspot.com/ My HA Blog
>>> Author of: Linux Smart Homes For Dummies
>> Jason Perkins
>> 313 355 0085 <(313)%20355-0085>
> Jason Perkins
> 313 355 0085
