[vcf-midatlantic] I guess another Apple 1 is up for Sale
corey cohen coreyvcf at gmail.com
Thu Mar 16 12:26:51 EDT 2017
One more thing also.  Many Apple-1 boards had mods or damage so the cleaner, less molested, the better is becoming important.
corey cohen
uǝɥoɔ ʎǝɹoɔ
> On Mar 16, 2017, at 9:25 AM, corey cohen <coreyvcf at gmail.com> wrote:
> Well some original components are still available, not all.  Some similar replacement parts are avail, but non date correct are avail.    It is still exactly like a vintage car because you may have to sacrifice a less rare model to get things up and running.
> Going forward it's more about originality for a running unit and what original accessories are with it.  Too many of the known working Apple-1 have replacement electrolytic big blue caps with date codes in the 80's.
>  Also we are starting to see some of the "Apple" defective boards coming out.  Some of them never ran.   I'm helping someone out with one of those now.  It's a lot more than simply replacing components.
> corey cohen
> uǝɥoɔ ʎǝɹoɔ
>> On Mar 16, 2017, at 9:08 AM, mike willegal via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> When I first started the registry, remarkably few Apple 1s had been powered up in any recent timeframe.    Since then, a lot more have been turned up, so to speak.  I started just logging the most recent time each one had been known to be operated.  Since replacement components are still available, I currently consider the number kind of meaningless, since with little to a lot of effort, any one of them could be operated.  It's not like some vintage airplanes or cars, where some key components may not be available to repair a broken unit.
>> regards,
>> Mike Willegal
