[vcf-midatlantic] I guess another Apple 1 is up for Sale
Jason Perkins
perkins.jason at gmail.com
Thu Mar 16 13:33:27 EDT 2017
"Fortunately most aged parts can be electronically restored if you catch
them early enough and know what your doing."
That sounds like a great VCF session :)
-J
On Thu, Mar 16, 2017 at 1:26 PM, corey cohen via vcf-midatlantic <
> Actually I have found a great degree of reliability issues if the
> restoration does't check all the boxes. The original design is pretty
> marginal and when stuff ages or drifts out of spec, the boards won't work
> as well as a replica with newer components. Fortunately most aged parts
> can be electronically restored if you catch them early enough and know what
> your doing.
> corey cohen
> uǝɥoɔ ʎǝɹoɔ
> > On Mar 16, 2017, at 9:55 AM, mike willegal <mike at willegal.net> wrote:
> > The date code component thing is sort of like worrying about having a
> numbers matching car, it matters to some people a lot more than to others.
> > Once it is debugged, the computer operates exactly the same way if it is
> built with all 80's era components or all 1976 era components that were
> originally stuffed into the board by Steve Job's sister.
> > regards,
> > Mike Willegal
> >> On Mar 16, 2017, at 12:25 PM, corey cohen <coreyvcf at gmail.com> wrote:
> >> Well some original components are still available, not all. Some
> similar replacement parts are avail, but non date correct are avail. It
> is still exactly like a vintage car because you may have to sacrifice a
> less rare model to get things up and running.
> >> Going forward it's more about originality for a running unit and what
> original accessories are with it. Too many of the known working Apple-1
> have replacement electrolytic big blue caps with date codes in the 80's.
> >> Also we are starting to see some of the "Apple" defective boards
> coming out. Some of them never ran. I'm helping someone out with one of
> those now. It's a lot more than simply replacing components.
> >> corey cohen
> >> uǝɥoɔ ʎǝɹoɔ
> >>> On Mar 16, 2017, at 9:08 AM, mike willegal via vcf-midatlantic <
> >>> When I first started the registry, remarkably few Apple 1s had been
> powered up in any recent timeframe. Since then, a lot more have been
> turned up, so to speak. I started just logging the most recent time each
> one had been known to be operated. Since replacement components are still
> available, I currently consider the number kind of meaningless, since with
> little to a lot of effort, any one of them could be operated. It's not
> like some vintage airplanes or cars, where some key components may not be
> available to repair a broken unit.
> >>> regards,
> >>> Mike Willegal
Jason Perkins
313 355 0085
