[vcf-midatlantic] Repairs to a Heath WH19 Terminal
David Gesswein djg at pdp8online.com
Sun Mar 26 16:58:46 EDT 2017
On Sun, Mar 26, 2017 at 04:51:30PM -0400, Jason Perkins via vcf-midatlantic wrote:
> After the regulator I measure 61.5 volts DC w/ .35v to .41v of ripple at
> 60hz. - sounds like it's not regulating much
> Reading the manual more, it doesn't use an integrated voltage regulator
> "The unregulated 65-volts DC from the power supply circuit board enters the
> video circuit board at plug P202, pins 2 and 3.
> Assume that the Terminal has just been turned on and the output of the
> +53-volt regulator is at zero volts.
Didn't have time to look at the schematic but if you are reading 61.5V on
the 53V output the regulator probably isn't regulating so its not filtering
the ripple. Are you able to understand the circuit to see how it should be
regulating and that the correct output should be close to 53 volts?
