[vcf-midatlantic] PET keyboard question
Chris Fala chrisjpf33 at gmail.com
Thu Nov 2 17:58:14 EDT 2017
I think Doug C. put some kind of paint-on metallic silver stuff on the carbon pads, and "The 8-Bit Guy" (YouTube) did too.
On Nov 2, 2017, at 5:49 PM, william degnan via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
I could but I am looking for  what someone who successfully restored a dead
keyboard did.  I never heard anyone putting colloidal silver on a pet
keyboard before.
Bill Degnan
twitter: billdeg
vintagecomputer.net
On Nov 2, 2017 4:48 PM, "Jeffrey Brace via vcf-midatlantic" <
How about putting silver on the contacts?
On Thu, Nov 2, 2017 at 4:21 PM, william degnan via vcf-midatlantic <
> I used the 91% with qtip on both.  I could try the eraser why not...but my
> method should have worked
> Bill Degnan
> twitter: billdeg
> vintagecomputer.net
> On Nov 2, 2017 3:53 PM, "Justin Jernigan via vcf-midatlantic" <
>>>> I searched the web and did not find any specific best way to handle
> keys
>>>> that have no response at all given my described situation. Most places
>> say
>>>> "clean everything"....OK tried that. What does one do specifically
>>>> (materials and procedure) to clean the black carbon contact points to
>>>> ensure conductivity? This is not the same issue as the SOL/Tandy-II
>>>> keyboard problem with the dried-out pads. The PET has springs, and
this
>>>> particular keyboard has no rust and very little crud. There must be
>>>> something microscopic like a thin film that needs to be cleared. I
>> believe
>>>> the pads are extending and contacting the control board. I tried using
>>>> deoxit and isopropyl alcohol. Hope I did not ruin. I was able to get a
>>>> few keys to work but there are a lot more to fix.
>> I use alcohol (91%) and a qtip on both the contact points and the carbon
>> pads.  Have you tried using a pencil eraser on the board contact points?
>> Might be worth it on the carbon points as well (pencil eraser) and then
>> clean again with alcohol.
