[vcf-midatlantic] IT stuff we need for the museum
systems_glitch systems.glitch at gmail.com
Mon Nov 6 08:12:35 EST 2017
You have to watch with no-name PoE injectors, most of them are not 802.3af
compliant and will often either not work with 802.3af stuff or can actually
damage it. Have someone confirm compatibility before purchasing.
I'll have to see what I have w.r.t. available switches, if you have to buy
something Allied Telesis makes some excellent basic managed PoE switches. I
believe their smaller offerings are fanless. You will be hard-pressed to
find a 24-port switch with PoE and no fans, it's just too much heat in 1U
to cool without forced air.
Thanks,
Jonathan
On Sat, Nov 4, 2017 at 10:48 PM, David Riley via vcf-midatlantic <
> On Nov 4, 2017, at 12:09 PM, Evan Koblentz <evan at vcfed.org> wrote:
> > >> If you have a switch you really like but it doesn't have PoE, I can
> highly recommend one of these:
> > How does that install? Unclear...
> It's a pass-thru that injects the PoE power on the unused pairs
> (100Base-TX only uses two pairs, the power uses the other two).  Just put
> the box after the switch, put the cameras on the other side.  802.3af (the
> 100 Mbps standard) is considerably simpler than the gigabit version, which
> has complex autonegotiation requirements and the like.
> > >> I have some spare rack mount 100 Mbps switches (including at least
> one fanless one
> > More details please.
> I'll send you some details offline, probably tomorrow when I've had a
> chance to have a look.
> - Dave
