[vcf-midatlantic] Looking for BR1951-L05 chips
Richard Cini
rich.cini at gmail.com
Mon Nov 6 08:53:27 EST 2017
Thanks Jeff. I dug through my parts box last night and found a COM5016 and a few AY5-8116 chips. As you point out the 8116 is pin compatible (I didn’t know that before) as is the 5016.
The L06 chip apparently has a higher error rate (3%) at 9600 and 19200 baud than the L05, attributed to the divisor (x32) and the input clock.
I’m going to design the board with a few jumpers to allow for the power supply differences too and see how it goes. If I wind up needing them I’ll let you know.
Rich
Get Outlook for iOS<https://aka.ms/o0ukef>
_____________________________
From: Jeff Galinat via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org<mailto:vcf-midatlantic at lists.vintagecomputerfederation.org>>
Sent: Monday, November 6, 2017 8:44 AM
Subject: Re: [vcf-midatlantic] Looking for BR1951-L05 chips
To: <vcf-midatlantic at lists.vintagecomputerfederation.org<mailto:vcf-midatlantic at lists.vintagecomputerfederation.org>>
Cc: Jeff Galinat <jgalinat at optonline.net<mailto:jgalinat at optonline.net>>
On 11/5/2017 7:13 PM, Richard Cini via vcf-midatlantic wrote:
> Does anyone have a cache of these WD baud rate generator chips? I just mistakenly bought three of the L06 versions but it turns out I need the L05 version, the difference being the divisor (I think) and the crystal. I’m going to re-create a Seattle Computer board and it uses the L05 version, and the software relies on the right divisor.
> If anyone has spares, please let me know. Thanks!
Hi Rich,
I couldn't find a datasheet for the WD BR1951 only a BR1941 part. I
checked what I have and I have a number of SMC COM8116 baud rate
generators which appear to be pin compatible with the BR1941 parts
except they only require a 5v supply. Here is a link to the data sheet
found on the web.
<http://matthieu.benoit.free.fr/cross/data_sheets/COM8116.pdf>
You can let me know if they will work in your application and I can get
a few to you.
Regards,
Jeff
