[vcf-midatlantic] Slide rules, lots and lots of 'em
Dave McGuire
mcguire at neurotica.com
Tue Nov 7 22:40:30 EST 2017
On 11/07/2017 09:36 PM, Glenn Roberts via vcf-midatlantic wrote:
> Ah a fellow RPI'er! I was one of the minions lugging my Keuffel & Esser up and down the hills of Troy, but lo and behold a piece of pocket-sized engineering beauty began to appear on campus (among those lucky, or rich enough) - the HP-35 "slide rule" pocket calculator! It would be a few calculator generations later that I could afford one (the HP-21) but I was hooked for life on HP and RPN! Nothin like em!
Right there with you on that. I use an HP-48GX at my desk, an HP-41CV
on the RF bench, and an HP-49G in the calibration lab.
I also have one of the SwissMicros HP-16C clones, if you don't know
about those you should check 'em out. Their models emulate the
processors and run the actual HP firmware.
-Dave
Dave McGuire, AK4HZ
New Kensington, PA
