[vcf-midatlantic] FS: Cut Down 11-Slot S-100 Backplane
systems_glitch
systems.glitch at gmail.com
Wed Nov 15 11:32:52 EST 2017
link: https://www.ebay.com/itm/272935251503
This appears to be a Quick and Timely "Silence Plus" 22-slot backplane that
has been cut down for use as a small test rig. Whoever cut it did a decent
job, the edge is dressed with gaffer's tape, and the ground traces (which
provide coax-like shielding) have been jumpered across at the cut edge.
One slot has two bent pins. I can desolder and/or replace the socket if
desired.
The backplane is mounted on plastic runners, presumably to allow it to be
laid on a tabletop or metallic surface without shorting anything out.
Thanks,
Jonathan
