[vcf-midatlantic] vax scsi questions
Jim Scheef
js at sdf.org
Sat Oct 7 21:57:43 EDT 2017
Bill,
Are the two SCSI port two separate bus or two ports on the same bus
(controller)? If there is only one bus, terminate the empty connector. If
there are two bus, turn off the empty bus. This is standard SCSI.
Duplicate SCSI ID's are a no-no and must be fixed. All devices on the bus
must has a unique ID.
Hope this is what you asked.
Jim
On Sat, 7 Oct 2017, william degnan via vcf-midatlantic wrote:
> Date: Sat, 7 Oct 2017 12:34:58 -0400
> From: william degnan via vcf-midatlantic
> <vcf-midatlantic at lists.vintagecomputerfederation.org>
> To: vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org>
> Cc: william degnan <billdegnan at gmail.com>
> Subject: [vcf-midatlantic] vax scsi questions
> working through from VAX 3100 / microvax SCSI drives. Three questions /
> looking for confirmation
> 1) true/false - it does not matter which scsi connector port you use, as
> long as the last drive's unconnected port has a terminator
> 2) true/false - drives have their names (DKB500, DKB300, etc) and they
> travel with the drive even if removed
> 3) true/false - show dev shows all drives attached to the computer that
> are properly terminated.
> 4) If question 2 is true and there are two drives with the same name, how
> does the VAX handle this? ignore the 2nd of same name?
> Thanks
> Bill
js at sdf.org
SDF Public Access UNIX System - http://sdf.lonestar.org
