[vcf-midatlantic] vax scsi questions
Jim Scheef
js at sdf.org
Sat Oct 7 22:06:28 EDT 2017
Ok, I have no idea what you are asking about the names.
Jim
On Sat, 7 Oct 2017, william degnan via vcf-midatlantic wrote:
> Date: Sat, 7 Oct 2017 12:34:58 -0400
> From: william degnan via vcf-midatlantic
> <vcf-midatlantic at lists.vintagecomputerfederation.org>
> To: vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org>
> Cc: william degnan <billdegnan at gmail.com>
> Subject: [vcf-midatlantic] vax scsi questions
> working through from VAX 3100 / microvax SCSI drives. Three questions /
> looking for confirmation
> 1) true/false - it does not matter which scsi connector port you use, as
> long as the last drive's unconnected port has a terminator
> 2) true/false - drives have their names (DKB500, DKB300, etc) and they
> travel with the drive even if removed
> 3) true/false - show dev shows all drives attached to the computer that
> are properly terminated.
> 4) If question 2 is true and there are two drives with the same name, how
> does the VAX handle this? ignore the 2nd of same name?
> Thanks
> Bill
js at sdf.org
SDF Public Access UNIX System - http://sdf.lonestar.org
