[vcf-midatlantic] vax scsi questions
william degnan
billdegnan at gmail.com
Mon Oct 9 12:18:37 EDT 2017
> Minimum boot will not execute your system's SYSTARTUP_VMS (or *_V5 because
> you're living in the past).
ironic statement. In my case I just wanted to keep the license as-is being
all historical and all that I am. I have a VMS 7.2 or .3 on CD if I really
wanted to upgrade.
> That is, typically, where one would add MOUNT
> commands to mount other device volumes available to the system. When you
> DO startup the system minimally, there are many other aspects of *normal*
> VMS startup that are also bypassed. You can also modify the system startup
> in SYSGEN when you boot conversationally (>>> BOOT/[R5:]1) and define the
> startup to the OPA0: (SYSBOOT> SET/STARTUP OPA0:). WHen your system boots,
> it will leave you at the DCL prompt ($). No need to even know the SYSTEM
> password or login to the SYSTEM account. However, when you do this, there
> is no error handling! A error, even a typo precipitating an unknown
> command
> syntax error, will kick you out with no resolve other than to reboot. The
> trick here is to issue a "$ SPAWN" command first. This way, you'll have a
> subprocess that, if it terminates, will dump you back into the STARTUP pro-
> cess. NOTE: If you change the startup, you will want to change it back.
> Conversationally boot. SYSBOOT> SET/STARTUP SYS$SYSTEM:STARTUP.COM and
> SYSBOOT> CONTINUE.
I ran this
SYSBOOT> SET STARTUP_P1 = " "
SYSBOOT> CONTINUE
problem is now the computer always tries to boot into the network. I need
to re-establish a boot into DKB500. I thought this would work:
SYSBOOT> SET STARTUP_P1 = "DKB500"
but I am starting to think with V5 you need to do it this way:
SYSBOOT> SET STARTUP_P1 = "DKB500:" (with the colon)
On my systems, I MOUNT volumes in a procedure (I call SYSTARTUP_MOUNT.COM)
> that I run as a detached process. If it hangs up on a MOUNT I can still,
> eventually after STARTUP.COM and its scion complete, login.
That makes sense. I still have a ways to go to make a safe system exposed
to the outside WWW as well. One thing about VMS, it let's you make
catastrophic mistakes without protest. Very flexible OS though.
Bill
