[vcf-midatlantic] VMS question
william degnan
billdegnan at gmail.com
Thu Oct 19 17:22:41 EDT 2017
Update complete, but it still kicks the user out after logging in. I think
you fixed a different issue. What else can I check? I had this same
problem and you fixed it for me at VCF East 12. I have notes about other
stuff we did on the system, but not about the users.
Username: EKOBLENTZ
Password:
Welcome to VAX/VMS version V5.5-2 on node COBUCK
Last interactive login on Thursday, 19-OCT-2017 15:14
%Sorry, your default device is unavailable for login, try again later...
EKOBLENTZ logged out at 19-OCT-2017 15:14:38.56
B
On Thu, Oct 19, 2017 at 5:10 PM, william degnan <billdegnan at gmail.com>
wrote:
> OK. Thanks for fixing my structure, I would not have caught that.
> Bill
> On Thu, Oct 19, 2017 at 4:18 PM, Brian Schenkenberger via vcf-midatlantic
> <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> william degnan via vcf-midatlantic writes:
>> >A while back I was working on my MicroVAX and I had a few OS and hardware
>> >setbacks. I have finally gotten back to where I was before.
>> >So, I have a question for you VMS admins out there.
>> >I can log into my Microvax 3100 as SYSTEM remotely the FQDN is
>> >microvax3100.vintagecomputer.net. I am having issues adding new users.
>> I
>> >remember asking about this problem a year ago and Brian helped me fix it
>> at
>> >VCF E 12 I think, but I forget how he fixed it.
>> >I can create a user (for Evan K to try) and I can log in, but it
>> >immediately logs me out. I get the following error:
>> >Username: EKOBLENTZ
>> >Password:
>> >I remember Brian S fixed this problem, and it's not a user setup issue
>> >within AUTH, there is something else I need to do to allow non SYSTEM
>> users
>> >to log in.
>> >This is not a production server but I do have it up and running now, if
>> >anyone who can advise needs the SYSTEM password just send me an email
>> and I
>> >will send to you. Please if you fix, I need to document the fix so I can
>> >know how to create a new user.
>> >Here is the process I am using:
>> >$ set process/privileges=all
>> >$ set default sys$system:
>> >$ run authorize
>> >UAF> show [100,*] /brief
>> >UAF> add EKOBLENTZ /uic=[100,30] /account=COBK
>> >UAF> modify EKOBLENTZ /password=password
>> >UAF> modify EKOBLENTZ /device=sys$sysdevice <=== L@@K
>> >UAF> modify EKOBLENTZ /directory=[EKOBLENTZ] <=== L@@K
>> >UAF> modify EKOBLENTZ /owner="Evan Koblentz"
>> >UAF> modify EKOBLENTZ /nopwdexpir /flag=nodisuser
>> >UAF> modify EKOBLENTZ /defprivileges=(TMPMBX, OPER, NETMBX)
>> >/privileges=(TMPMBX, OPER, NETMBX)
>> >UAF> modify EKOBLENTZ /flags=nodisuser
>> >UAF> exit
>> >$ create /directory /owner=[100,30] COBK$DATA:[COBK.PERSONAL.ekoblentz]
>> <=== L@@K
>> >/OWNER=[ekoblentz]
>> >SO...What else do I need to do? I know my SYSTARTUP_V5.COM is a little
>> >screwy (yes I am using VMS 5.2) and I need to clean it up, but I don't
>> >think the problem described above is related to the system start
>> script. I
>> >seem to remember Brian going into a directory someplace and adding the
>> user
>> >to a table or changing the system to allow a certain user to be able to
>> log
>> >in. What I'd like is to allow any user I create by default to be allowed
>> >to log in, if they have the correct permissions as a user.
>> >Thanks
>> >Bill
>> You have created/established Evan's account with a default "home"
>> directory of
>> SYS$SYSDEVICE:[EKOBLENTZ] but you created COBK$DATA:[COBK.PERSONAL.EKOBL
>> ENTZ].
>> Either:
>> (1)
>> $ MCR AUTHORIZE
>> UAF> modify EKOBLENTZ /device=COBK$DATA:
>> UAF> modify EKOBLENTZ /directory=[COBK.PERSONAL.EKOBLENTZ]
>> ...or...
>> (2)
>> $ CREATE/DIRECTORY SYS$SYSDEVICE:[EKOBLENTZ]/OWNER=[100,10]
>> Remember, computers only do what you tell them to do. ;)
