[vcf-midatlantic] VMS question
william degnan
billdegnan at gmail.com
Fri Oct 20 00:18:35 EDT 2017
Jason
I am using 5.2, there is no ssh. Brian Schl... helped me last time this
happened, I am just missing a permission table thing or something, this
particular machine has a custom set up that he helped me uncover. I just
neglected to document the process.
FYI For historic reasons I'd like to keep it as I got it, I don't want to
upgrade the OS.
Bill Degnan
twitter: billdeg
vintagecomputer.net
On Oct 20, 2017 12:04 AM, "Jason Howe via vcf-midatlantic" <
> Hrm. If I can manage it this weekend, I'll pull out my DEC 3000. I
> *think* I built a newuser script which takes care of enough stuff to just
> allow a login for a new user without any hassle.
> I have a vague recollection of an ssh difficulty on first login and that
> telnet or a console login for the first login was most reliable. That
> might be specific to VMS 8.4 or just my setup though.
> --Jason
> On 10/19/2017 02:22 PM, william degnan via vcf-midatlantic wrote:
>> Update complete, but it still kicks the user out after logging in. I
>> think
>> you fixed a different issue. What else can I check? I had this same
>> problem and you fixed it for me at VCF East 12. I have notes about other
>> stuff we did on the system, but not about the users.
>> Username: EKOBLENTZ
>> Password:
>> Welcome to VAX/VMS version V5.5-2 on node COBUCK
>> Last interactive login on Thursday, 19-OCT-2017 15:14
>> %Sorry, your default device is unavailable for login, try again later...
>> EKOBLENTZ logged out at 19-OCT-2017 15:14:38.56
>> B
>> On Thu, Oct 19, 2017 at 5:10 PM, william degnan <billdegnan at gmail.com>
>> wrote:
>> OK. Thanks for fixing my structure, I would not have caught that.
>>> Bill
>>> On Thu, Oct 19, 2017 at 4:18 PM, Brian Schenkenberger via vcf-midatlantic
>>> <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>>> william degnan via vcf-midatlantic writes:
>>>> A while back I was working on my MicroVAX and I had a few OS and
>>>>> hardware
>>>>> setbacks. I have finally gotten back to where I was before.
>>>>> So, I have a question for you VMS admins out there.
>>>>> I can log into my Microvax 3100 as SYSTEM remotely the FQDN is
>>>>> microvax3100.vintagecomputer.net. I am having issues adding new users.
>>>> I
>>>>> remember asking about this problem a year ago and Brian helped me fix
>>>>> it
>>>> at
>>>>> VCF E 12 I think, but I forget how he fixed it.
>>>>> I can create a user (for Evan K to try) and I can log in, but it
>>>>> immediately logs me out. I get the following error:
>>>>> Username: EKOBLENTZ
>>>>> Password:
>>>>> later...
>>>>> I remember Brian S fixed this problem, and it's not a user setup issue
>>>>> within AUTH, there is something else I need to do to allow non SYSTEM
>>>> users
>>>>> to log in.
>>>>> This is not a production server but I do have it up and running now, if
>>>>> anyone who can advise needs the SYSTEM password just send me an email
>>>> and I
>>>>> will send to you. Please if you fix, I need to document the fix so I
>>>>> can
>>>>> know how to create a new user.
>>>>> Here is the process I am using:
>>>>> $ set process/privileges=all
>>>>> $ set default sys$system:
>>>>> $ run authorize
>>>>> UAF> show [100,*] /brief
>>>>> UAF> add EKOBLENTZ /uic=[100,30] /account=COBK
>>>>> UAF> modify EKOBLENTZ /password=password
>>>>> UAF> modify EKOBLENTZ /device=sys$sysdevice <=== L@@K
>>>>> UAF> modify EKOBLENTZ /directory=[EKOBLENTZ] <=== L@@K
>>>>> UAF> modify EKOBLENTZ /owner="Evan Koblentz"
>>>>> UAF> modify EKOBLENTZ /nopwdexpir /flag=nodisuser
>>>>> UAF> modify EKOBLENTZ /defprivileges=(TMPMBX, OPER, NETMBX)
>>>>> /privileges=(TMPMBX, OPER, NETMBX)
>>>>> UAF> modify EKOBLENTZ /flags=nodisuser
>>>>> UAF> exit
>>>>> $ create /directory /owner=[100,30] COBK$DATA:[COBK.PERSONAL.ekobl
>>>>> entz]
>>>> <=== L@@K
>>>>> /OWNER=[ekoblentz]
>>>>> SO...What else do I need to do? I know my SYSTARTUP_V5.COM is a
>>>>> little
>>>>> screwy (yes I am using VMS 5.2) and I need to clean it up, but I don't
>>>>> think the problem described above is related to the system start
>>>> script. I
>>>>> seem to remember Brian going into a directory someplace and adding the
>>>> user
>>>>> to a table or changing the system to allow a certain user to be able to
>>>> log
>>>>> in. What I'd like is to allow any user I create by default to be
>>>>> allowed
>>>>> to log in, if they have the correct permissions as a user.
>>>>> Thanks
>>>>> Bill
>>>> You have created/established Evan's account with a default "home"
>>>> directory of
>>>> SYS$SYSDEVICE:[EKOBLENTZ] but you created COBK$DATA:[COBK.PERSONAL.EKOBL
>>>> ENTZ].
>>>> Either:
>>>> (1)
>>>> $ MCR AUTHORIZE
>>>> UAF> modify EKOBLENTZ /device=COBK$DATA:
>>>> UAF> modify EKOBLENTZ /directory=[COBK.PERSONAL.EKOBLENTZ]
>>>> ...or...
>>>> (2)
>>>> $ CREATE/DIRECTORY SYS$SYSDEVICE:[EKOBLENTZ]/OWNER=[100,10]
>>>> Remember, computers only do what you tell them to do. ;)
