[vcf-midatlantic] VMS question
william degnan
billdegnan at gmail.com
Fri Oct 20 09:21:46 EDT 2017
I noticed when I logged in today a file / info dump printed to the screen
but when I logged out and in again it was gone. Perhaps that's what you're
talking about?
Understand that I did not write SYSLOGIN.COM or any of this configuration
... I would not have imagined someone would have a messed up SYSLOGIN.COM
to cause the issue you described. There may be another explanation.
I am trying to "take over" from where they guy that set this machine up
left off and learn how this particular server was set up and why. I want
to fix, but I also know System administration tends to reflect the
personality of the admin, people have reasons for things. I am making the
assumption that given this was a production system there must be some
reasons for things. Eventually I can try to improve.
When I log in using Evan's account, I can get in but I have a disk quota
exceeded error when I try to generate an email message.
MAIL> mail
To: SMTP%"evan at snarc.net"
Subj: VAX USERN/PASS
%MAIL-E-OPENOUT, error opening
COBK$DATA:[COBK.PERSONAL.EKOBLENTZ]MAIL_0128_SEND
.TMP; as output
-RMS-E-CRE, ACP file create failed
-SYSTEM-F-EXDISKQUOTA, disk quota exceeded
Thanks for you help.
Bill
On Fri, Oct 20, 2017 at 8:55 AM, Brian Schenkenberger via vcf-midatlantic <
> The problem was a poorly written SYLOGIN.COM file!!! That "Sorry%"
> message
> was found in the SYLOGIN.COM file.
> Evan's password will need to be reset. It is presently the magic word from
> Adventure twice. ;)
> Sadly, the stupid SYLOGIN.COM, redefined command DELETE, so the
> SYLOGIN.COM
> file is NO LONGER there. It didn't do all that much and what it did to was
> wrong and stupid, so start over and learn some DCL.
