[vcf-midatlantic] VMS question
william degnan
billdegnan at gmail.com
Fri Oct 20 14:00:04 EDT 2017
On Fri, Oct 20, 2017 at 1:17 PM, Brian Schenkenberger via vcf-midatlantic <
> william degnan via vcf-midatlantic writes:
> >Brian, Do you know anything about why now I can't edit COM files like
> >they are text files, it seems like you deleted all of the old versions
> >of systartup_v5.com that I was saving. can you please advise how to
> >return the EDIT command to show a text editor style, rather than a VI
> >type edit style? Bill
> I did not touch SYSTARTUP_V5.COM. Why would you NOT be able to edit a
> .COM file? It's just text. The editors on VMS are not brain-damaged
> to decide what's in a file based upon file extension like on other OS.
I CAN edit it, but now it's just a * prompt like VI, I used to be able to
see the entire file and edit it like a text file. Now I have to use the
arcane asterisk prompt commands. Personal preference, I prefer a text type
editor. My question is - not did you touch that file, did you change the
nature of the EDIT command itself somehow?
To be precise I would type
$ EDIT systartup_v5.com [enter] (for example)
... and I would be greeted by a screen full of the file, so that I could
use the cursor to jump around the file.
Now, when I type
... I see this:
C*
My question for you is, did you change the OS to change the way EDIt by
default works, but more important why is this now happening and how can I
get into a text editor style mode?
Bill
