[vcf-midatlantic] semi OT: BBC micro:bit on sale at Microcenter
Neil Cherry
ncherry at linuxha.com
Tue Sep 19 14:56:52 EDT 2017
The Pi W is an OTG device so you need the correct cable to convert it to normal
USB (and then into the hub). But you can configure the SD card with the correct
information and it should boot. Problem is that they've disable the sshd by
default (grrr). I haven't figured out how to get around that on the SD.
So you'll probably need a monitor, keyboard and mouse to set it up the
first time.
Linux Home Automation Neil Cherry ncherry at linuxha.com
http://www.linuxha.com/ Main site
http://linuxha.blogspot.com/ My HA Blog
Author of: Linux Smart Homes For Dummies
