[vcf-midatlantic] TDL SMB Repair Writeup
systems_glitch systems.glitch at gmail.com
Wed Aug 1 10:43:17 EDT 2018
Thanks! I was glad to be able to bring this one back from the boneyard,
hopefully my experience helps others along the way, too.
Thanks,
Jonathan
On Tue, Jul 31, 2018 at 10:35 PM, Douglas Crawford via vcf-midatlantic <
> On 7/31/2018 10:32 PM, systems_glitch via vcf-midatlantic wrote:
>> Last October, I traded Herb Johnson for two TDL SMB boards that had been
>> stripped of all socketed parts, and even some of the soldered-down ones!
>> Here's my writeup on the repair process:
>> http://www.glitchwrks.com/2018/07/31/tdl-smb
>> Both boards had an etch error that shorted the +5V rail to ground! This is
>> presumably why they ended up in the TDL boneyard. Herb had acquired them
>> stripped of all parts from a former TDL employee, presumably someone
>> plugged it in, noticed the power draw, and moved on to the next board. I
>> found the short by stripping one board of its sockets and bisecting the
>> +5V
>> rail with trace cuts. The short was hidden under silkscreen, making it
>> invisible.
>> In the process, I did two things that will probably be useful to other
>> people here: I designed a replacement board for the SEMI 4804 SRAMs, which
>> are unobtainium, and I reproduced the Interface One and Interface 2 I/O
>> breakout boards. All will be available through my Tindie store as I get
>> time to photograph and list them, but if you're in need of them now, send
>> me an email!
>> The writeup also covers the cuts and jumps necessary to use 2716 EPROMs
>> instead of the mask ROM that TDL originally supplied with the SMB. There
>> are pictures of my modifications, with the cut areas circled for clarity.
>> Thanks,
>> Jonathan
> As usual, awesome job there, Jonathan!
