[vcf-midatlantic] DEC KDF-11 question
David Riley fraveydank at gmail.com
Fri Aug 3 09:19:33 EDT 2018
Seconded. 2.9BSD works fine on F11 chipsets; my 11/23 handles it just fine.
If you're in search of one, I might have one spare.  Let me know if you're still looking and I'll poke around in my stash (which needs reorganization anyway).
If in doubt, try out your intended system in SimH first.  It'll usually give you an OK idea whether it'll work.
- Dave
> On Aug 1, 2018, at 12:02 PM, Ethan Dicks via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> You could run 2.9BSD on a KDF11.  I've done it on an 11/24.
> -ethan
> On Wed, Aug 1, 2018, 09:54 Richard Cini via vcf-midatlantic <
>> All —
>> I’m looking for a working M8186/KDF-11 dual-height CPU card, mostly as an
>> experiment to see if it would work in place of the LSI-11 (11/03) card in
>> my Heath H-11 for the purposes of getting BSD 2.11 working. Not sure if
>> that’s even possible, so maybe let’s start with that.
>> Will BSD run on a KDF-11 (11/23) if I have sufficient RAM?
>> Thanks!
>> Rich
>> Get Outlook for iOS
>> Get Outlook for iOS<https://aka.ms/o0ukef>
