[vcf-midatlantic] Working Tandy 1000 or 2000
Jonathan Gevaryahu
jgevaryahu at gmail.com
Thu Aug 30 15:52:26 EDT 2018
Interestingly, so far the tech manual has been correct about the sound
chips.
The tech manual for the SX however claimed that it uses the "8040328"
BIOS, which is version 01.01.00
but it uses a bios which is 01.02.00, with an unknown number? Maybe some
SX machines shipped with the 8040328 and some with whatever the tandy
part number is for the later bios?
Can you snap a pic of the bios chip in your SX?
On 8/30/2018 3:20 PM, Kelly Leavitt wrote:
> OK, I'll see if I have the TX. Based on the (known unreliable)
> technical reference manual, the 1000TX uses the NCR 8496.
> *From:* Jonathan Gevaryahu <jgevaryahu at gmail.com>
> *Sent:* Thursday, August 30, 2018 2:21 PM
> *To:* Kelly Leavitt; Dean Notarnicola; vcf-midatlantic
> *Subject:* Re: [vcf-midatlantic] Working Tandy 1000 or 2000
> The 1000TX I've heard (but am not sure) uses an NCR8496, but again,
> just a rumor.
> On 8/30/2018 10:23 AM, Kelly Leavitt wrote:
>> Just confirmed, my 1000SX has the SN76496 TI chip. I'll have to look
>> at the others in this family.
>> *From:* Dean Notarnicola <dnotarnicola at gmail.com>
>> <mailto:dnotarnicola at gmail.com>
>> *Sent:* Wednesday, August 29, 2018 11:48 PM
>> *To:* vcf-midatlantic
>> *Cc:* Jonathan Gevaryahu; Kelly Leavitt
>> I just picked up an SX. I'll check it in the morning
>> On Wed, Aug 29, 2018 at 11:13 PM Jonathan Gevaryahu via
>> vcf-midatlantic <vcf-midatlantic at lists.vcfed.org
>> <mailto:vcf-midatlantic at lists.vcfed.org>> wrote:
>> The problem is I've found that the parts lists in some of the Tandy
>> manuals is incorrect.
>> On 8/29/2018 10:11 PM, Kelly Leavitt wrote:
>> > OK, sorry I got that backward. I have an SX apart on the bench for
>> > some testing. I cannot find any chip with either part number.
>> It is
>> > either hiding under a Tandy house number or part of the 2 big
>> (for the
>> > time) ASICs. I'm pulling up the technical reference manual now.
>> > OK, according to the parts list on P51, U37A is an SN76496 Tone
>> > Generator. That agrees with page 7 of the schematic.
>> > I've attached screen grabs of these if they don't get stripped.
>> > You can find the tech ref for the 1000sx at
>> ftp://ftp.mindcandydvd.com/pub/drivers/Tandy/Tandy_1000SX_Technical_Reference_Manual.pdf
>> > I'll verify the part number of IC U37A tomorrow.
>> <mailto:jgevaryahu at gmail.com>>
>> > *Sent:* Wednesday, August 29, 2018 9:18 PM
>> > *To:* Kelly Leavitt; vcf-midatlantic
>> > The TI chip is fairly well understood; the original Tandy
>> 1000/1000HD,
>> > and the slightly enhanced 1000A used the 'real' TI chip,
>> SN76496, for
>> > certain.
>> > Its possible that the EX (and maybe HX?) also used it, but unclear.
>> > The SX and TX (and maybe the HX?) SUPPOSEDLY used the weird
>> NCR8496
>> > chip, which is what I need tested. (assuming wikipedia is correct,
>> > which it actually isn't regarding the SN76496 on the Tandy
>> 1000/1000A...)
>> > The SL2, TL2, RLX, RSX use the PSSJ-3 ASIC, which would also be
>> ok for
>> > testing, but ideally I'd like to run these tests on both the
>> NCR8496
>> > and the PSSJ-3.
>> > On 8/29/2018 8:36 AM, Kelly Leavitt wrote:
>> >> I have manyof the 1000 series computers (hx, ex, sx, sl, sl2, tl,
>> >> etc). Do you know which used the wonky TI chip? I can always
>> start
>> >> opening them up.
>> >> <mailto:jgevaryahu at gmail.com <mailto:jgevaryahu at gmail.com>>
>> >> *Sent:* Wednesday, August 29, 2018 12:55 AM
>> >> Another thing: I need to test against a tandy 1000-series with an
>> >> NCR8496 or PSSJ-1 asic in it, i.e. not the original tandy
>> >> 1000/1000a/1000hd, since they actually use a real TI SN76496 PSG
>> >> which actually behaves differently! (that's the whole reason I
>> need
>> >> to do these tests, the behavior isn't consistent!)
>> >> On 8/29/2018 12:53 AM, Jonathan Gevaryahu wrote:
>> >>> Indeed, I was thinking of the 1000 series, not the 2000.
>> >>> I'm trying to figure the best way to run the tests from basic, i
>> >>> might need to mess around with dosbox to get the program
>> written,
>> >>> since MAME has keyboard issues with the tandy machines (which
>> I'd
>> >>> also love to fix...)
>> >>> On 8/28/2018 8:45 PM, Kelly Leavitt wrote:
>> >>>> The 2000 and the 1000 were remarkably different beasts. The
>> 2000
>> >>>> had a basic speaker that did beeps. There was a rumored TV
>> board
>> >>>> but I have never seen one in the wild. Fun tidbit, the 2000
>> loaded
>> >>>> BIOS from floppy (a 720k 5.25 inch floppy). The built in ROM
>> was a
>> >>>> simple boot loader.
>> >>>> The 1000 was mostly compatible with the XT/jr with some
>> added sound
>> >>>> and graphics capabilities.
>> >>>> I have working models of the 1000 hear that I cant test with
>> >>>> Tandy's Basica if you'd like. My 2000's are iffy so I can't
>> make
>> >>>> any promises. Send me the pokes you'd like to try.
>> >>>> Kelly
>> >>>> kelly at catcorner.org <mailto:kelly at catcorner.org>
>> <mailto:kelly at catcorner.org <mailto:kelly at catcorner.org>>
>> >>>> *From:* vcf-midatlantic
>> <vcf-midatlantic-bounces at lists.vcfed.org
>> <mailto:vcf-midatlantic-bounces at lists.vcfed.org>>
>> <mailto:vcf-midatlantic-bounces at lists.vcfed.org>> on behalf of
>> >>>> Jonathan Gevaryahu via vcf-midatlantic
>> >>>> *Sent:* Sunday, August 26, 2018 5:16 AM
>> >>>> *To:* vcf-midatlantic at lists.vcfed.org
>> >>>> *Subject:* [vcf-midatlantic] Working Tandy 1000 or 2000
>> >>>> Does VCF have a working Tandy 1000 or 2000 on display or in the
>> >>>> warehouse?
>> >>>> I need someone with access to a working Tandy 1000/2000 to
>> do some
>> >>>> poking from basic of the sound chip, since there's an issue I'm
>> >>>> running
>> >>>> into with a possible incompatibility of the Tandy 1000/2000
>> NCR8496
>> >>>> PSG
>> >>>> (sound chip) and the more common SN76489/SN76496 PSG which the
>> >>>> colecovision etc used.
> Jonathan Gevaryahu
> jgevaryahu at hotmail.com <mailto:jgevaryahu at hotmail.com>
Jonathan Gevaryahu
