[vcf-midatlantic] Working Tandy 1000 or 2000
Jonathan Gevaryahu
jgevaryahu at gmail.com
Fri Aug 31 00:20:25 EDT 2018
U41 must be 01.03.00, then. (does the Tandy 1000SX display that during
boot?)
Can you snap a pic of the ROM chip? I need to document the exact label
on it.
On 8/30/2018 8:18 PM, Kelly Leavitt wrote:
> Found a 1000TX in the dungeon. Have to get it out.
> Took a picture of U41 in my SX, which I believe is the the ROM. It is
> Tandy part number 8079015. Makers mark is a capital (and serrifed) GI.
> That does not agree with any ICs on the parts list.
> Hope this helps.
> My guess is the Tech Ref is based on 01.01.00. The later version of
> BIOS has a different internal part number.
> Kelly
> *From:* Jonathan Gevaryahu <jgevaryahu at gmail.com>
> *Sent:* Thursday, August 30, 2018 3:52 PM
> *To:* Kelly Leavitt; Dean Notarnicola; vcf-midatlantic
> *Subject:* Re: [vcf-midatlantic] Working Tandy 1000 or 2000
> Interestingly, so far the tech manual has been correct about the sound
> chips.
> The tech manual for the SX however claimed that it uses the "8040328"
> BIOS, which is version 01.01.00
> but it uses a bios which is 01.02.00, with an unknown number? Maybe
> some SX machines shipped with the 8040328 and some with whatever the
> tandy part number is for the later bios?
> Can you snap a pic of the bios chip in your SX?
> On 8/30/2018 3:20 PM, Kelly Leavitt wrote:
>> OK, I'll see if I have the TX. Based on the (known unreliable)
>> technical reference manual, the 1000TX uses the NCR 8496.
>> <mailto:jgevaryahu at gmail.com>
>> *Sent:* Thursday, August 30, 2018 2:21 PM
>> The 1000TX I've heard (but am not sure) uses an NCR8496, but again,
>> just a rumor.
>> On 8/30/2018 10:23 AM, Kelly Leavitt wrote:
>>> Just confirmed, my 1000SX has the SN76496 TI chip. I'll have to look
>>> at the others in this family.
>>> *From:* Dean Notarnicola <dnotarnicola at gmail.com>
>>> <mailto:dnotarnicola at gmail.com>
>>> *Sent:* Wednesday, August 29, 2018 11:48 PM
>>> *To:* vcf-midatlantic
>>> *Cc:* Jonathan Gevaryahu; Kelly Leavitt
>>> I just picked up an SX. I'll check it in the morning
>>> On Wed, Aug 29, 2018 at 11:13 PM Jonathan Gevaryahu via
>>> vcf-midatlantic <vcf-midatlantic at lists.vcfed.org
>>> <mailto:vcf-midatlantic at lists.vcfed.org>> wrote:
>>> The problem is I've found that the parts lists in some of the Tandy
>>> manuals is incorrect.
>>> On 8/29/2018 10:11 PM, Kelly Leavitt wrote:
>>> > OK, sorry I got that backward. I have an SX apart on the bench
>>> for
>>> > some testing. I cannot find any chip with either part number.
>>> It is
>>> > either hiding under a Tandy house number or part of the 2 big
>>> (for the
>>> > time) ASICs. I'm pulling up the technical reference manual now.
>>> > OK, according to the parts list on P51, U37A is an SN76496 Tone
>>> > Generator. That agrees with page 7 of the schematic.
>>> > I've attached screen grabs of these if they don't get stripped.
>>> > You can find the tech ref for the 1000sx at
>>> ftp://ftp.mindcandydvd.com/pub/drivers/Tandy/Tandy_1000SX_Technical_Reference_Manual.pdf
>>> > I'll verify the part number of IC U37A tomorrow.
>>> <mailto:jgevaryahu at gmail.com>>
>>> > *Sent:* Wednesday, August 29, 2018 9:18 PM
>>> > *To:* Kelly Leavitt; vcf-midatlantic
>>> > The TI chip is fairly well understood; the original Tandy
>>> 1000/1000HD,
>>> > and the slightly enhanced 1000A used the 'real' TI chip,
>>> SN76496, for
>>> > certain.
>>> > Its possible that the EX (and maybe HX?) also used it, but
>>> unclear.
>>> > The SX and TX (and maybe the HX?) SUPPOSEDLY used the weird
>>> NCR8496
>>> > chip, which is what I need tested. (assuming wikipedia is
>>> correct,
>>> > which it actually isn't regarding the SN76496 on the Tandy
>>> 1000/1000A...)
>>> > The SL2, TL2, RLX, RSX use the PSSJ-3 ASIC, which would also
>>> be ok for
>>> > testing, but ideally I'd like to run these tests on both the
>>> NCR8496
>>> > and the PSSJ-3.
>>> > On 8/29/2018 8:36 AM, Kelly Leavitt wrote:
>>> >> I have manyof the 1000 series computers (hx, ex, sx, sl, sl2,
>>> tl,
>>> >> etc). Do you know which used the wonky TI chip? I can always
>>> start
>>> >> opening them up.
>>> >> <mailto:jgevaryahu at gmail.com <mailto:jgevaryahu at gmail.com>>
>>> >> *Sent:* Wednesday, August 29, 2018 12:55 AM
>>> >> Another thing: I need to test against a tandy 1000-series
>>> with an
>>> >> NCR8496 or PSSJ-1 asic in it, i.e. not the original tandy
>>> >> 1000/1000a/1000hd, since they actually use a real TI SN76496 PSG
>>> >> which actually behaves differently! (that's the whole reason
>>> I need
>>> >> to do these tests, the behavior isn't consistent!)
>>> >> On 8/29/2018 12:53 AM, Jonathan Gevaryahu wrote:
>>> >>> Indeed, I was thinking of the 1000 series, not the 2000.
>>> >>> I'm trying to figure the best way to run the tests from
>>> basic, i
>>> >>> might need to mess around with dosbox to get the program
>>> written,
>>> >>> since MAME has keyboard issues with the tandy machines
>>> (which I'd
>>> >>> also love to fix...)
>>> >>> On 8/28/2018 8:45 PM, Kelly Leavitt wrote:
>>> >>>> The 2000 and the 1000 were remarkably different beasts. The
>>> 2000
>>> >>>> had a basic speaker that did beeps. There was a rumored TV
>>> board
>>> >>>> but I have never seen one in the wild. Fun tidbit, the 2000
>>> loaded
>>> >>>> BIOS from floppy (a 720k 5.25 inch floppy). The built in
>>> ROM was a
>>> >>>> simple boot loader.
>>> >>>> The 1000 was mostly compatible with the XT/jr with some
>>> added sound
>>> >>>> and graphics capabilities.
>>> >>>> I have working models of the 1000 hear that I cant test with
>>> >>>> Tandy's Basica if you'd like. My 2000's are iffy so I can't
>>> make
>>> >>>> any promises. Send me the pokes you'd like to try.
>>> >>>> Kelly
>>> >>>> kelly at catcorner.org <mailto:kelly at catcorner.org>
>>> <mailto:kelly at catcorner.org <mailto:kelly at catcorner.org>>
>>> >>>> *From:* vcf-midatlantic
>>> <vcf-midatlantic-bounces at lists.vcfed.org
>>> <mailto:vcf-midatlantic-bounces at lists.vcfed.org>>
>>> <mailto:vcf-midatlantic-bounces at lists.vcfed.org>> on behalf of
>>> >>>> Jonathan Gevaryahu via vcf-midatlantic
>>> >>>> *Sent:* Sunday, August 26, 2018 5:16 AM
>>> >>>> *To:* vcf-midatlantic at lists.vcfed.org
>>> >>>> *Subject:* [vcf-midatlantic] Working Tandy 1000 or 2000
>>> >>>> Does VCF have a working Tandy 1000 or 2000 on display or in
>>> the
>>> >>>> warehouse?
>>> >>>> I need someone with access to a working Tandy 1000/2000 to
>>> do some
>>> >>>> poking from basic of the sound chip, since there's an issue
>>> I'm
>>> >>>> running
>>> >>>> into with a possible incompatibility of the Tandy 1000/2000
>>> NCR8496
>>> >>>> PSG
>>> >>>> (sound chip) and the more common SN76489/SN76496 PSG which the
>>> >>>> colecovision etc used.
>> Jonathan Gevaryahu
>> jgevaryahu at hotmail.com <mailto:jgevaryahu at hotmail.com>
> Jonathan Gevaryahu
Jonathan Gevaryahu
