[vcf-midatlantic] Any trick to discharging ADM-3A
Joseph Oprysko joprysko1 at gmail.com
Thu Feb 8 09:27:42 EST 2018
I would say yes. As long as not removing the rubber anode cup, the tube
connector on the end and/yoke can be removed without discharging the tube.
I had removed/swapped around several early Mac tubes without discharging
the monitor.
On Thu, Feb 8, 2018 at 8:51 AM corey cohen <coreyvcf at gmail.com> wrote:
> Ok.  Well then let me ask you and Ian this..
> Can I safely disconnect the plug at the end of the CRT neck without
> discharging?
> That would make it easier to take the tube out while the anode wire is
> still connected and then in can discharge the tube with a screwdriver.
> Also is the best place to clip onto the implosion bracket since the ADM
> doesn’t really have a metal chassis?
> Thanks,
> Corey
> *corey cohen*
> *uǝɥoɔ ʎǝɹoɔ*
> On Feb 8, 2018, at 12:01 AM, Joseph Oprysko via vcf-midatlantic <
> vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> I’ve done the screwdriver trick myself. Because often, even after waiting a
> few weeks, there can still be enough voltage to make your hair stand on
> end. LOL
> On Wed, Feb 7, 2018 at 7:05 PM Ian Primus via vcf-midatlantic <
> I don't remember any particular trick or real difficulty in doing it.
> Maybe you needed to get the tube loose to get the screwdriver in
> there? But I thought it would fit in there without too much problem. I
> know I've done it a whole bunch of times and nothing sticks out at me
> as being out of the ordinary about working on the 3A. Remember you
> don't need to disconnect the anode connection right away, just
> discharge it.
> If you're doing a lot of work on one of those monitors, sometimes you
> do need to get a bit creative though:
> https://i.imgur.com/k2wPmw3.jpg
> https://i.imgur.com/UwU3gek.jpg
> -Ian
> On Wed, Feb 7, 2018 at 6:29 PM, corey cohen via vcf-midatlantic
> <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> So I was about to swap out my ADM5 for my ADM3a with my ALTAIR and
> realized while I did replace the electrolytic and tantalum caps on the main
> board, I didn’t change the electrolytic caps on the analog board behind the
> tube.
> No big deal except that the rubber cup is on the top where I can’t get
> to it without removing the tube and you aren’t really supposed to remove
> the tube till you discharge it under the rubber cup.    So chicken or the
> egg?
> Or am I just supposed to let the ADM sit unplugged for a few weeks and
> just assume it self discharged?
> Just when I thought I was finished with this project and was going to
> move onto my TI silent rebuild.
> Thanks,
> Cheers,
> Corey
> corey cohen
> uǝɥoɔ ʎǝɹoɔ
> Normal Person: Hey, it seems that you know a lot.
> Geek: To be honest, it's due to all the surfing I do.
> Normal Person: So you go surfing?
> Normal Person: But I don't think that has anything to do with knowing a
> lot...
> Geek: I think that's wrong on a fundamental level.
> Normal Person: Huh? Huh? What?
lot...
