[vcf-midatlantic] Any trick to discharging ADM-3A
Neil Cherry ncherry at linuxha.com
Thu Feb 8 13:33:30 EST 2018
On 02/08/2018 12:12 PM, David Riley wrote:
> On Feb 8, 2018, at 11:08 AM, Neil Cherry via vcf-midatlantic
> <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> My reference for the cold water pipe was for use with the screw driver to ground.
> Well, the cold water pipe will connect to EARTH ground, which if your house is wired
> correctly should be the same as ground on your power outlets.  But since you're doing
> this with the system unplugged (you're doing this with the system unplugged, right?),
> it has no connection to the tube/chassis ground, which is what you really want.
Very good point.
I don't recall if it was unplugged. I don't think it was but I can't recall.
I do know we worked on live systems with the scope (Isolated).
Linux Home Automation         Neil Cherry       ncherry at linuxha.com
http://www.linuxha.com/                         Main site
http://linuxha.blogspot.com/                    My HA Blog
Author of:    	Linux Smart Homes For Dummies
