[vcf-midatlantic] Is there anyway to caps lock an ADM3a?
Dean Notarnicola
dnotarnicola at gmail.com
Tue Feb 13 07:02:05 EST 2018
I know you did your own research, but as far as I can see, most seemed to
remap caps lock to escape, then instead use ctrl-[ to send esc to the
computer.
Dean
On Tue, Feb 13, 2018 at 5:40 AM corey cohen via vcf-midatlantic <
> I know on the adm5 there is an actual caps lock key.
> On the 3a, I can’t seem to find it in the manuals other than setting the
> dip switch to upper case. Which is not practical.
> Thanks,
> Corey
> corey cohen
> uǝɥoɔ ʎǝɹoɔ
