[vcf-midatlantic] Is there anyway to caps lock an ADM3a?
corey cohen
coreyvcf at gmail.com
Tue Feb 13 07:49:53 EST 2018
> On Feb 13, 2018, at 7:02 AM, Dean Notarnicola <dnotarnicola at gmail.com> wrote:
> I know you did your own research, but as far as I can see, most seemed to remap caps lock to escape, then instead use ctrl-[ to send esc to the computer.
> Dean
>> On Tue, Feb 13, 2018 at 5:40 AM corey cohen via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> I know on the adm5 there is an actual caps lock key.
>> On the 3a, I can’t seem to find it in the manuals other than setting the dip switch to upper case. Which is not practical.
>> Thanks,
>> Corey
>> corey cohen
>> uǝɥoɔ ʎǝɹoɔ
How do they remap? Rewire or is there a dip switch setting I’m not understanding?
Thanks,
Corey
