[vcf-midatlantic] Is there anyway to caps lock an ADM3a?
Dean Notarnicola
dnotarnicola at gmail.com
Tue Feb 13 08:07:09 EST 2018
Someone with more experience in this than me may have a better answer, but
as far as I can see it’s modifying the termcap entries on the different
systems you’re connecting to.
On Tue, Feb 13, 2018 at 7:49 AM corey cohen <coreyvcf at gmail.com> wrote:
> On Feb 13, 2018, at 7:02 AM, Dean Notarnicola <dnotarnicola at gmail.com>
> wrote:
> I know you did your own research, but as far as I can see, most seemed to
> remap caps lock to escape, then instead use ctrl-[ to send esc to the
> computer.
> Dean
> On Tue, Feb 13, 2018 at 5:40 AM corey cohen via vcf-midatlantic <
> vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> I know on the adm5 there is an actual caps lock key.
>> On the 3a, I can’t seem to find it in the manuals other than setting the
>> dip switch to upper case. Which is not practical.
>> Thanks,
>> Corey
>> corey cohen
>> uǝɥoɔ ʎǝɹoɔ
> How do they remap? Rewire or is there a dip switch setting I’m not
> understanding?
> Thanks,
> Corey
