[vcf-midatlantic] Is there anyway to caps lock an ADM3a?
corey cohen
coreyvcf at gmail.com
Tue Feb 13 09:37:10 EST 2018
> On Feb 13, 2018, at 8:07 AM, Dean Notarnicola <dnotarnicola at gmail.com> wrote:
> Someone with more experience in this than me may have a better answer, but as far as I can see it’s modifying the termcap entries on the different systems you’re connecting to.
>> On Tue, Feb 13, 2018 at 7:49 AM corey cohen <coreyvcf at gmail.com> wrote:
>>> On Feb 13, 2018, at 7:02 AM, Dean Notarnicola <dnotarnicola at gmail.com> wrote:
>>> I know you did your own research, but as far as I can see, most seemed to remap caps lock to escape, then instead use ctrl-[ to send esc to the computer.
>>> Dean
>>>> On Tue, Feb 13, 2018 at 5:40 AM corey cohen via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>>>> I know on the adm5 there is an actual caps lock key.
>>>> On the 3a, I can’t seem to find it in the manuals other than setting the dip switch to upper case. Which is not practical.
>>>> Thanks,
>>>> Corey
>>>> corey cohen
>>>> uǝɥoɔ ʎǝɹoɔ
>> How do they remap? Rewire or is there a dip switch setting I’m not understanding?
>> Thanks,
>> Corey
Don’t think that will work on a 1975 ALTAIR, guess that’s what people are doing who hook up to a Linux box or raspberryPi.
