[vcf-midatlantic] Is there anyway to caps lock an ADM3a?
corey cohen coreyvcf at gmail.com
Tue Feb 13 11:19:28 EST 2018
Yes all you have to do is add two 2102 ram chips and a lower case version of the 2513 character generator.  I got my chip from Wendell Sander who got it from the last of Mike Willegal’s stash.
corey cohen
uǝɥoɔ ʎǝɹoɔ
> On Feb 13, 2018, at 10:36 AM, Bill Degnan via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> The original ADM3a's they only had capital letters until one bought and
> installed the mixed case ROM upgrade, right?
> On Tue, Feb 13, 2018 at 9:45 AM, William Dudley via vcf-midatlantic <
>> WHY WOULD YOU WANT CAPS LOCK, ANYWAY?
>> just curious.
>> Bill Dudley
>> This email is free of malware because I run Linux.
>> On Tue, Feb 13, 2018 at 9:37 AM, corey cohen via vcf-midatlantic <
>>>> On Feb 13, 2018, at 8:07 AM, Dean Notarnicola <dnotarnicola at gmail.com>
>>> wrote:
>>>> Someone with more experience in this than me may have a better answer,
>>> but as far as I can see it’s modifying the termcap entries on the
>> different
>>> systems you’re connecting to.
>>>>> On Tue, Feb 13, 2018 at 7:49 AM corey cohen <coreyvcf at gmail.com>
>> wrote:
>>>>>> On Feb 13, 2018, at 7:02 AM, Dean Notarnicola <
>>> wrote:
>>>>>> I know you did your own research, but as far as I can see, most
>> seemed
>>> to remap caps lock to escape, then instead use ctrl-[ to send esc to the
>>> computer.
>>>>>> Dean
>>>>>>> On Tue, Feb 13, 2018 at 5:40 AM corey cohen via vcf-midatlantic <
>>>>>>> I know on the adm5 there is an actual caps lock key.
>>>>>>> On the 3a, I can’t seem to find it in the manuals other than setting
>>> the dip switch to upper case.  Which is not practical.
>>>>>>> Thanks,
>>>>>>> Corey
>>>>>>> corey cohen
>>>>>>> uǝɥoɔ ʎǝɹoɔ
>>>>> How do they remap?  Rewire or is there a dip switch setting I’m not
>>> understanding?
>>>>> Thanks,
>>>>> Corey
>>> Don’t think that will work on a 1975 ALTAIR, guess that’s what people are
>>> doing who hook up to a Linux box or raspberryPi.
