[vcf-midatlantic] Ideas on replacing a backlighting on a laptop
Ethan O'Toole telmnstr at 757.org
Mon Jun 4 09:44:28 EDT 2018
> I'd start by looking at the inverter board. From pictures online, it looks
> like that laptop uses an blue electroluminescent sheet for the backlight,
> not a ccfl like more modern laptops.
> -J
EL backlighting has a fairly short halflife I believe.
Maybe it's possible to get a new sheet of it.
Converting it over to use modern LED backlighting systems might be another
trick, but I don't know if modern laptops run LED PWD in time to the
screen refresh, or if there is room where the EL sheet was.
 			- Ethan O'Toole
