[vcf-midatlantic] Orientation of vented cover for airflow
systems_glitch
systems.glitch at gmail.com
Fri Jun 8 16:42:56 EDT 2018
Rich,
Drawing air in, pushing it across the power supply, into the card cage, and
out the far edge of the card cage.
Thanks,
Jonathan
On Fri, Jun 8, 2018 at 3:09 PM, William Sudbrink via vcf-midatlantic <
> Ok. I found at least some of it. Several of the 1977 issues of _Kilobaud_
> contained a running discussion of optimizing airflow in an S-100 chassis,
> including the IMSAI. Looking at the October issue now:
> https://archive.org/stream/kilobaudmagazine-1977-10/
> Kilobaud_1977_October_dj
> vu.txt
> Bill S.
> -----Original Message-----
> From: vcf-midatlantic
> [mailto:vcf-midatlantic-bounces at lists.vintagecomputerfederation.org] On
> Behalf Of Richard Cini via vcf-midatlantic
> Sent: Friday, June 08, 2018 2:23 PM
> To: vcf-midatlantic
> Cc: Richard Cini
> Subject: [vcf-midatlantic] Orientation of vented cover for airflow
> All -
> I have a question regarding S100 cabinet airflow. Here's the setup.
> I just bought a TEi enclosure (12-slot, impeccably clean) on eBay. The
> power
> supply is to the right of the card cage, the fan blows inward and it was
> delivered with the cover installed such that the air vents are on the right
> (power supply) side.
> To me, this seems counterintuitive. I would think that the vents should be
> on the left with the fan blowing out so as to draw air through the card
> cage, over the power supply and then out the back.
> On my IMSAI (both sides of the cover are vented) and the fan blows out, but
> the vents next to the power supply are sealed with tape.
> Any thoughts on this?
> Thanks!
> Rich
> Get Outlook for iOS<https://aka.ms/o0ukef>
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
