[vcf-midatlantic] Computer terminal in WarGames
Ethan O'Toole
telmnstr at 757.org
Fri Jun 15 10:54:48 EDT 2018
> From what I recall, WOPR's voice was made by having a person (John Wood, same
> actor as who played Dr. Falken) read back the lines to be said with the words
> in reverse sentence order, then the recordings were spliced back into the
> correct order and a bunch of filters (vocoder?) applied to them. I'm not sure
> if the words were spoken in monotone and pitched up down by varying the
> recording speeds or not, or if the vocoder did this?
That sounds right.
The WarGames DVD has the alt audio track that has the people talking about
making the movie. That is probably where I heard about the vocoder.
Not sure about them pitching it up or down. The vocoders then were quite a
bit more simple than the modern emulators I'm sure. These days they would
use autotune I guess :-)
The whole reason for the speach is because it would be too boring to watch
Lightman just type back and forth.
Man, I'm going to have to watch the movie again with all this talk :-)
WarGames and Hackers, two greats.
- Ethan
