[vcf-midatlantic] PAL c64 - Power supply
Tony Bogan thebogans at mac.com
Sun Jun 17 18:40:48 EDT 2018
If it's a two or three prong European plug he should be able to just plug it into the step up transformer I dropped off. It is designed to handle several different European "standards"
Just make sure you set it to step up the voltage and not down (it's a switch and some jumpers to make changes so you'd have to go out of your way to screw it up.......fortunately we are talking about jeff and not Evan ;-)
Tony
Sent from my iPhone
> On Jun 17, 2018, at 6:13 PM, Evan Koblentz <evan at vcfed.org> wrote:
>> So the PAL c64 has a different type of power supply. A european two prong
>> type. Does anyone know what it will take to convert power to American 120V?
>> I need to start planning on how to get this machine up and tested at the
>> next workshop June 30.
> Tony gave us a step-down adapter for the BBC Micro (240). Tony: will that same device work with Jeff's PAL 64?
