[vcf-midatlantic] A/B switch for ribbon cable?
Evan Koblentz evan at vcfed.org
Fri Jun 22 14:32:42 EDT 2018
> Dumb question
Yes, it is. :)
> are you sure it's not 25 pins?
I'm definitely not as good at math as most people in this group, but I
can count to 20 in decimal.
> What is the 20 pin cable for the Lego robot?
It connects the cards to the interface box. We have a (clone) Lego card
for the Apple II (which I'm using with a Laser 128) and an original Lego
card for the IBM PC (which I'm using with a Compaq Portable III). I will
need to swap the interface box between these computers on a regular
basis, so it would be nice to have a switch device rather than keep
plugging/unplugging the cable.
