[vcf-midatlantic] A/B switch for ribbon cable?
William Sudbrink
wh.sudbrink at gmail.com
Fri Jun 22 14:37:33 EDT 2018
Yes, but he said he only needs 20 pins.
Bill S.
-----Original Message-----
From: vcf-midatlantic [mailto:vcf-midatlantic-bounces at lists.vcfed.org] On Behalf Of Ethan Dicks via vcf-midatlantic
Sent: Friday, June 22, 2018 1:57 PM
To: vcf-midatlantic
Cc: Ethan Dicks
Subject: Re: [vcf-midatlantic] A/B switch for ribbon cable?
On Fri, Jun 22, 2018 at 12:22 PM, systems_glitch via vcf-midatlantic
<vcf-midatlantic at lists.vcfed.org> wrote:
> You can probably use a 25-pin A/B switch (super common, used for switching
> a printer between two PCs) and just make up cables for it. Just make sure
> it's the printer variety, with all pins switched -- some of the ones
> intended for RS-232 don't switch every single pin.
Right. Check all pins. Even on the "full" ones, some of them have
24-pole switches not 25-pole.
-ethan
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
