[vcf-midatlantic] A/B switch for ribbon cable?
Ethan Dicks ethan.dicks at gmail.com
Fri Jun 22 14:49:49 EDT 2018
On Fri, Jun 22, 2018 at 2:37 PM, William Sudbrink via vcf-midatlantic
<vcf-midatlantic at lists.vcfed.org> wrote:
> Yes, but he said he only needs 20 pins.
You have to be sure to use the correct 20 out of 25 or sadness ensues.
-ethan
> -----Original Message-----
> From: vcf-midatlantic [mailto:vcf-midatlantic-bounces at lists.vcfed.org] On Behalf Of Ethan Dicks via vcf-midatlantic
> Sent: Friday, June 22, 2018 1:57 PM
> To: vcf-midatlantic
> Cc: Ethan Dicks
> Subject: Re: [vcf-midatlantic] A/B switch for ribbon cable?
> On Fri, Jun 22, 2018 at 12:22 PM, systems_glitch via vcf-midatlantic
>> You can probably use a 25-pin A/B switch (super common, used for switching
>> a printer between two PCs) and just make up cables for it. Just make sure
>> it's the printer variety, with all pins switched -- some of the ones
>> intended for RS-232 don't switch every single pin.
> Right.  Check all pins.  Even on the "full" ones, some of them have
> 24-pole switches not 25-pole.
> -ethan
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
