[vcf-midatlantic] Anyone going to HOPE?
systems_glitch systems.glitch at gmail.com
Mon Jun 25 17:29:07 EDT 2018
Definitely something to note: if you're not used to the standards of "cheap
hotel room in NYC," the Hotel Penn might be a bit of a shock to you. I've
never seen evidence of bugs or rodents in rooms I've been in, and no one I
personally know has either, which is about all you can say for the
older/cheaper rooms at the Hotel Penn. Last time Ethan and I split a room,
the AC was leaking condensate all over the carpet and made it smell a bit
like death in there. Fortunately I had my security bits in my toolbox and
was able to open the window :P
Beware that they will also try and stick a daily housekeeping charge on
your bill, after you check out.
Thanks,
Jonathan
On Mon, Jun 25, 2018 at 5:22 PM, Ethan O'Toole via vcf-midatlantic <
> Anyone from VCF going to HOPE this year?
>> The date snuck up on me, and now the hotel Penn is full. If someone knew
>> of
>> a good / inexpensive place to stay for this conference I'm all ears!
> I will be there! Crashing with a friend I know from the old school hacker
> scene though, I didn't setup the hotel.
> From MAGFest knowledge, it might be that the HOPE Hotel block is full.
> Check to see if the room is available with or without the HOPE code. The
> next thing is there is some 5000 club or something that gets access to
> nicer (meaning a normal hotel grade) room.
> Also more rooms might open up as the event gets closer, but it's a pain
> being on that line.
