[vcf-midatlantic] Thicknet/10base5 Test Segment: The Cable is In!
VAXman at tmesis.org
Tue Jun 26 17:42:39 EDT 2018
systems_glitch via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
writes:
>Heh, yes, this roll should last for a *little* while :P As long as
>you're not in a hurry, I can drop it off next time I'm up your way for
>work! It'd look nice, connected to a Unibus Ethernet board :)
Via an AUI, of course, as you can't connect it directly.
