[vcf-midatlantic] Thicknet/10base5 Test Segment: The Cable is In!
systems_glitch
systems.glitch at gmail.com
Tue Jun 26 18:06:04 EDT 2018
Well, of course :) Unless you're putting BNC connectors on the thicknet,
there's nothing it can directly attach to, as far as I know.
A good place to use one of those huge old DEC H4000s!
Thanks,
Jonathan
On Tue, Jun 26, 2018 at 5:42 PM, Brian Schenkenberger via vcf-midatlantic <
> systems_glitch via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
> writes:
> >Heh, yes, this roll should last for a *little* while :P As long as
> >you're not in a hurry, I can drop it off next time I'm up your way for
> >work! It'd look nice, connected to a Unibus Ethernet board :)
> Via an AUI, of course, as you can't connect it directly.
