[vcf-midatlantic] Good news / please read, Re: museum network rack
Herb Johnson hjohnson at retrotechnology.info
Fri Jun 29 16:27:02 EDT 2018
The good news about buying a new unit, is new batteries. Any donated
unit would have old or no batteries, you'd have to buy new ones for use.
Typically gel-cell batteries are tens of dollars each plus tens of
dollars shipping, bigger cost more. Your unit (reading the manual)
probably uses three 12V 7Ah batteries; those are common enough, probably
about $100 to replace. Probably replace every two-three years depending
on how many times they get discharged (extended power failures). When
they get cooked, they swell up, it's visible. Good luck!
My $10 worth
Herb Johnson
