[vcf-midatlantic] [Semi-OT] 3D Printing Replacement Parts (Was: Re: About Bill's message)
Evan Koblentz
evan at vcfed.org
Tue Mar 6 10:52:13 EST 2018
>> A concrete item that you can see today is the power switch on the IBM
PS/2 Model 76, in the museum. It was broken at some point in the past, and
I 3D printed a replacement.
Neat! I didn't know that.
Another example in the museum is the "k" in the StorageTek logo on the tape
library. The original was broken. Dan W. in IXR printed a new one, and then
the train club guys next door painted it to match.
On Mar 6, 2018 10:33 AM, "J. Alexander Jacocks via vcf-midatlantic" <
> A concrete item that you can see today is the power switch on the IBM PS/2
> Model 76, in the museum. It was broken at some point in the past, and I 3D
> One way that you can deal with the limited number of colors available in
> PLA/PET/ABS filament is to dye the results. For an example, see this
> article in Make <https://makezine.com/2013/05/
> 09/how-to-dye-your-3d-prints/>
> magazine.
> You can do quite a bit, and in very high quality, if you take the time to
> properly learn to design parts. All the things that are required for the
> design of professionally made injection-molded parts (clearance, tolerance,
> wear, etc.) are also necessary to get a good quality result out of FDM.
> And, of course, there is SLA, if you really need fine detail.
> And last, there are those, like myself, who also tinker in the subtractive
> manufacturing arena that is CNC machining. That produces quite a bit more
> robust parts, from any machinable material, including ferrous metals.
> The limiting factor in all these technologies is more the imagination and
> skill of the user, and less the technologies themselves. Sure,
> capabilities grow with time, but incredible things are made every day, with
> very basic tools.
> - Alex
> On Tue, Mar 6, 2018 at 5:16 AM, Dave Wade via vcf-midatlantic <
> > > -----Original Message-----
> > > From: vcf-midatlantic <vcf-midatlantic-
> > > bounces at lists.vintagecomputerfederation.org> On Behalf Of Herb Johnson
> > > via vcf-midatlantic
> > > Sent: 06 March 2018 03:35
> > > To: vcf-midatlantic <vcf-midatlantic at lists.
> > > Cc: Herb Johnson <hjohnson at retrotechnology.info>
> > > Subject: [vcf-midatlantic] About Bill's message
> > > > Creating a library of open-source vintage computing parts * IS * a
> > > > good idea. Bill: if you'd like to lead the effort then you have my
> > support.
> > > I agree, it's a good idea. If Bill agrees, I hope he changes the
> subject
> > line! hint
> > > hint
> > > There's a number of toggles that people try to 3D print, varying
> degrees
> > of
> > > success. Maybe keycaps? Light covers? These are small parts and
> printing
> > a
> > > few at a time gives some "scale" to the effort. Tricks like coloring
> the
> > plastics
> > > are good to know.
> > I think Keycaps are better made with modelling moulding compounds.
> > > Nice thing about collecting models, is that most all 3D printers use
> the
> > same
> > > modeling language. There are some collections of models out there (no
> > > magic "git" thank goodness) so those could be pointed to. I think I
> know
> > a
> > > few locations ....
> > > I'm not against 3D printers - just skeptical about their results. But
> > these are
> > > not a big stretch. And if there's cooperative colleagues among us to
> > test, we
> > > can find out! IXR locally also has, or had, a 3D printer
> > > - Neil can speak to that. Our friend Matt with the $200 printer, can
> > participate
> > > too. We might pass the hat to buy plastic noodles... it is OK to call
> > them that?
> > The results can be good, but its not just point and shoot. I think where
> > they really com in is for new prts to adapt old machines. E.g.
> > https://www.thingiverse.com/thing:1592139
> > Dave
> > > herb
> > > Herbert R. Johnson, New Jersey in the USA
> > > http://www.retrotechnology.com OR .net
> > > preserve, recover, restore 1970's computing
> > > email: hjohnson AT retrotechnology DOT com
> > > or try later herbjohnson AT retrotechnology DOT info
