[vcf-midatlantic] Fwd: Re: Museum report
Evan Koblentz
evan at vcfed.org
Mon Mar 19 00:33:24 EDT 2018
Thank you Doug/David.
I only used a small amount of Goof Off but it didn't work anyhow. Maybe
because the instructions say to let it dissolve the residue for a couple
of minutes, however, this is a vertical panel so when I put it onto the
residue most of it just dripped down. What's a better method, other than
removing the panels (not so easy to do; it requires removing whole
components not just typical latch-on panels.)
