[vcf-midatlantic] VCF BBS
John Heritage
john.heritage at gmail.com
Sun Mar 25 02:29:12 EDT 2018
Gotcha. 9600 is nice for text though :)
On Sat, Mar 24, 2018, 11:41 PM Evan Koblentz <evan at vcfed.org> wrote:
> >> If it has problems, you can probably also use analog fax adapters on
> VOIP setups to at least get 14.4kbps.
> I anticipate limiting it to 2400.
> On Sat, Mar 24, 2018, 8:43 PM John Heritage <john.heritage at gmail.com>
> wrote:
>> Looking forward to the BBS!
>> If it has problems, you can probably also use analog fax adapters on VOIP
>> setups to at least get 14.4kbps..
>> On Sat, Mar 24, 2018 at 7:06 PM, Evan Koblentz via vcf-midatlantic <
>> vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>>> As some of you may remember, last year we bought an inexpensive analog
>>> PBX for use with the planned BBS.
>>> Martin and I talked. He says it won't work with modems and that we *
>>> will * need Asterisk.
>>> We'll see. :)
