[vcf-midatlantic] OT -- URGENT -- Thunderbird help needed
Drew Notarnicola drew.notarnicola at gmail.com
Tue Mar 27 18:21:24 EDT 2018
Are you sure the profile is actually supposed to contain the whole
messages?  Maybe it does for IMAP and not for POP.  It's possible those
messages were actually stored elsewhere.  When was the last time you backed
up your entire hard drive?
On Tue, Mar 27, 2018 at 4:42 PM, Evan Koblentz via vcf-midatlantic <
> The Thunderbird message files are usually one file per folder. So if the
>> profile you have copied are there some files with the names of the folders
>> you are missing. ... but the mail is in the files with no extensions. Check
>> their content
> Oh, I understand now. Yes -- I was able to open some of the inbox files
> with a text editor and see contents. Didn't realize that Jeff S. was saying
> the same thing. However it looks like only a small amount of the contents
> vs. all the messages. I don't understand that, because I copied the whole
> profile.
> So how do I make Thunderbird understand that at least some contents ARE
> there?
