[vcf-midatlantic] talk at VCF-East on audio cassettes for data; stuff
Matt Patoray mspproductions at gmail.com
Fri May 11 08:51:10 EDT 2018
Kyle,
Since that is a 4 track drive/cart that will NOT be compatible with the
broadcast Fidelipac drives, as those are  2 track running at 7.5 IPS. 4
track would be a 4 track "Muntz" stereo cartridge running at 3 3/4 IPS,
which is what William Lear based the "Lear stereo 8". For the Fidelipac and
the Muntz machines the cartridge is exactly the same with the pinch roller
swinging up into the cart for playback, which is an advantage in this case
as the pinch roller that normally turns to goo, can be replaced in the
machine saving the tape carts from destruction.
On Fri, May 11, 2018 at 12:38 AM, Kyle Owen via vcf-midatlantic <
> This may be too beyond audio cassettes, but I figured I'd share.
> I never really was interested in this portion of my first PDP-8 haul, but I
> ended up with a Tennecomp Fidelipac drive. For those unfamiliar, these were
> commonly used for commercial breaks in radio stations and the stations'
> jingles. Similar to 8-track, but they didn't have a built-in pinch roller.
> I have yet to see if the unit is functional, and need to figure out where
> the interface card is (if it came with the interface, even), as I would
> like to digitize the tapes. Fortunately, I've got a friend with some radio
> station cart machines, so I could possibly record them to audio files and
> reverse engineer them from there.
> So yes, even a PDP-8/M, ca. 1974, and possibly prior, used an audio tape
> system for data storage!
> Pictures here: https://photos.app.goo.gl/kBL9gRGF697A0xUT2
> Kyle
Matt Patoray
Owner, MSP Productions
KD8AMG
