[vcf-midatlantic] how about a lovely vintage printer for that computer :-)
systems_glitch systems.glitch at gmail.com
Mon Nov 19 15:36:06 EST 2018
I've got two of these, one in case the other breaks (hah! yeah, right).
Excellent printers.
As Dave said, you can still get ribbons for most of these things. I bought
two 6-pack boxes of Nu-Kote ribbons for my old TTX daisy wheel printer a
year or so ago, probably a lifetime supply unless I start running some sort
of business form on them. Along those lines, I'm still running an old HP
LaserJet 4 as my main printer here, I've tried to replace it 3 or 4 times,
and all of its would-be replacements have died. I finally had Ian go
through it, apparently all of the roller assemblies and everything are not
only available, but pretty cheap!
> I bought 100 new MMJ connectors
Surprisingly, a bunch of telecom providers still have these in stock. Until
recently, Vnetek (the folks that, eventually, ended up with DEC's small
networks stuff) still carried the 100-pack under the original DEC part
number. I threw some in on the last order from Vnetek, apparently that was
the last of their MMJ connectors.
Thanks,
Jonathan
On Mon, Nov 19, 2018 at 12:15 PM Sentrytv via vcf-midatlantic <
> I sent a reply I'm interested
> Mike Rosen
> Sent from:
> My extremely complicated, hand held electronic device.
> > On Nov 19, 2018, at 8:22 AM, Jeffrey Brace via vcf-midatlantic <
> > If no one else wants it, then I will take it! I’m sure there is support
> for
> > it for Commodore 64 ;) At the very least GEOS should support.
> > On Sun, Nov 18, 2018 at 7:14 PM Jeffrey Jonas via vcf-midatlantic <
> >> I have some things that need adoption,
> >> starting with a lovely Panasonic KX-P1124
> >> 24 pin dot matrix printer.
> >> Come on, upgrade from that 9 pin printer already!
> > Jeff Brace
> > Vice President
> > Vintage Computer Federation
