[vcf-midatlantic] Jeff vs Steve
Jonathan Gevaryahu
jgevaryahu at gmail.com
Wed Nov 28 14:22:20 EST 2018
Make sure that the floppy drive on the canon cat has had the design-flaw plastic piece inside replaced with a metal piece instead, or it will randomly self-destruct the drive. IIRC the plastic piece holds the head rails to the drive case, and if it breaks the heads cannot retract, and if the diskette is ejected in that state the drive head gets torn completely off, totally ruining the drive.
The original delrin(?) plastic piece should be replaced with a piece of machined aluminum instead, from what I understand.
Sent from my iPhone
> On Nov 28, 2018, at 12:55 PM, andy diller via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> Here was my prototype - back in 2014
> http://dillernet.com/apple/2014/09/04/jeff-vs-steve/
> I just need to get the Canon Cat to print and I can make this happen- maybe in time for 2019 VCF East.
> -andy
