[vcf-midatlantic] Snipe-It
Andrew Diller
dillera at gmail.com
Thu Nov 29 21:34:40 EST 2018
Snipe-IT itself requires not much at all- it's minimum requirement is PHP 5.6 or later and MySQL. Apache HTTPD is the easiest to setup for PHP execution.
I'm running mine on a little Dell Optiplex 160 which is a core-solo cpu with 2G of ram, and it's also doing a few other things (like a jvm for a Confluence wiki I use), all running on ubuntu 14.04.
Snipe-it has a fully hosted SAAS at: https://snipit.io/ (which I'm sure you've seen).
I'm sure it could also run nicely on a DigitalOcean $10 a month droplet if you don't want a server sitting on the floor of the Infoage space.
As for modifications, it's PHP which is one of the reasons I'm going to use it for my things- that it probally the most modifiable of the options I had looked at when I was researching it.
-andy
> On Nov 29, 2018, at 2:18 PM, Evan Koblentz via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> From: Evan Koblentz <evan at snarc.net>
> Subject: Re: [vcf-midatlantic] Snipe-It
> Date: November 29, 2018 at 2:18:17 PM EST
> To: martin.flynn at compdecon.org, Eric Rangell via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
>> Eric,
>> Quick question - how well does the current version of Snipe-It run on Ubuntu Server 18.04.1 LTS on top of ESXi?
>> Might be usable to track stuff in the Makerspace (also at Infoage in Building 9059)
> I don't know if they have a server version. We were shopping for a cloud-based product.
