[vcf-midatlantic] Kind of OT: RS-485 to DMX-512
Martin Flynn
maflynn at theflynn.org
Fri Nov 30 18:14:27 EST 2018
On 11/30/2018 4:46 PM, Ethan O'Toole wrote:
>> Trying to get a lighting controller to talk to 1986 vintage
>> microprocessor based lighting control packs.
> This is my world!
>> The PHY layer of DMX-512 (lighting control protocol) is RS-485.
> Yes. Given that it's 1986, are you 100% sure it's DMX-512? If so you
> are good.
>> Anyone have code samples that could be used as a starting point, or
>> should I break down & buy the USB to DMX-512 cable?
> You can get a cheap ($7) FTDI based USB to RS485 dongle from amazon or
> eBay. The FTDI chip can't natively do the proper break space but they
> have a trick of resetting the chip to get the proper spacing for the
> restart of next set of 512 channels transmitted.
> With this adapter (which is similar to the $50 EnTec OpenDMX) you can
> use free software in windows like FreeStylerDMX or QLC+, or if you
> wish to go the linux route there is the Linux OLA package which can do
> Artnet and 1.31 sACN in and translate over to physical DMX512 (via
> RS485 dongle.) OLA has a web interface that lets you tickle the
> channels with a web fader board, and could easily be scripted.
> At the laser enthusiasts gathering I go to I've done a presentation or
> two on running OLA on a PI to do cheap Artnet/1.31 in over to DMX512.
> I can dig up the slides.
> Actually, since the presentation is on the evil cloud I just opened up
> access and here is the steps to install the OLA bits on debian/pi:
> https://docs.google.com/presentation/d/1MqJrwKCAL_tw4t-VnQWevSvXTlszwFy-clECES2YwY8/edit?usp=sharing
Lighting packs are Strand CD-80 with the aftermarket Johnson Systems
DPC-24 control modules, so yes, it's definitely DMX-512
Looking at the Open DMX USB as an option
