[vcf-midatlantic] Kind of OT: RS-485 to DMX-512
Ethan O'Toole telmnstr at 757.org
Fri Nov 30 19:34:36 EST 2018
> And DMX512 isn't so non-vintage computing related.  I did some faux lighting
> panels for a Thinking Machines CM-2 recently.  The controller is built around
> an ESP32 with BT/Wifi.  I thought about adding support for artnet so the 4096
> individually dim-able LEDs can be controlled with standard DMX universes :)
> Have to finish the project in January.  Would be a good way for non-technical
> museum people to setup lighting patterns.
> -Alan
CM/2? Where!? The one at the Mountain View Computer History Museum? I only
know of that CM2 in the wild, along with the Frostberg CM-5 at the NSA
museum up the road in Maryland.
A Cray and a Thinking Machines were my two "grails." I managed to get one,
and the sheer weight let it be the final big machine grail :-) When I saw
the CM-5 at the NSA Cryptographic Museum I was floored to find out it was
some 9' high and is likely to cause difficully going into a truck. Not to
mention through a normal door!
 			- Ethan
