[vcf-midatlantic] Xerox 16/8 M92 computer
Neil Cherry
ncherry at linuxha.com
Mon Aug 5 10:18:24 EDT 2019
On 8/4/19 6:16 PM, Herb Johnson via vcf-midatlantic wrote:
>> On Sat, Aug 03, 2019 at 11:13:28PM -0400, Evan Koblentz via vcf-midatlantic wrote:
>>> >> Does the museum have or need this?
>>> We have a couple of 820s, but we don't have this. Do we need it? I don't
>>> know... anyone have thoughts about that?
>> If you have other good examples of the dual processor PC with CP/M showing the
>> attempt to bridge the generations another may not be that significant. The page says it
>> may had a little better implementation than some with the concurrent processing.
> There were a number of microcomputers in the early 1980's, which incorporated both an 8085
> and an 8088, or a Z80 and an 8088. The Heath/Zenith Z-100 (Z-121) switched between an 8085
> or an 8088. The Compupro 8/16 used an 8085/8088 S-100 CPU card, similar circuits. I
> believe NorthStar had an 8088 board option for their Z80 based Advantage (non-S-100
> computer). There are other examples. Likewise, some MS-DOS computers ran an ISA bus Z80
> card (Baby Blue, etc.).
> Why do this? Because of the rise of MS-DOS during the age of CP/M-80. Keep in mind that
> through the late 1970s and into the 1980's, CP/M-80 was the leading Intel-compatible
> operating system. These 8088 options were ways to provide some kind of compatibility and
> future-support, for MS-DOS products and for "Big Blue" IBM. The Z80 cards for IBM PC's,
> was a way to run legacy software - until PCs were fast enough to emulate CP/M-80.
Interesting time, I have an ATR8000 for the Atari 8 bit computer. The
ATR8000 could run as a drive interface (8", 5 1/4 and 3 1/2) or CP/M
machine or with a coprocessor board a 8088 and run DOS. A very odd
time as no one knew what was going on with CP/M vs MSDOS.
Linux Home Automation Neil Cherry ncherry at linuxha.com
http://www.linuxha.com/ Main site
http://linuxha.blogspot.com/ My HA Blog
Author of: Linux Smart Homes For Dummies
